EU roaming not working
- 08-05-2024
That is what I was thinking of doing but with exception it would just be a EU wide one ongoing monthly as otherwise I would be switching back and forth between them and trying to manage multiple ones. The catch being of course the fact I don't know if the iphone will really just switch between them without me having to do anything and also if EU roaming is any better as I know my coworkers also sometimes have issues and they already are on EU plans.
It's not just a Smarty problem though, that is for sure. There may be better or other companies that don't have as many issues but catch is finding them without just literally trying them all 🙂
Have a look at "KeepGo" travel eSIMs, where any purchased data does not expire, as long as you top up a minimum of just $3 per year, which in your case, would seem to meet your needs well.
