LaurenS_2643774
07-05-2024SMARTY Maverick
EU roaming not working
Any tips for getting EU roaming to work on an iPhone? I have followed the steps suggested on the smarty website (going to mobile data network and changing the mobile data/MMS APN to mob.asm.net. Roam...
- 08-05-2024
Buberlub
06-07-2024SMARTY Pioneer
I’m getting nothing in Malaga had to buy an e sim roaming was the reason I went for Smarty it previously worked in Lanzarote
