EU roaming not working
- 08-05-2024
Thanks for all your replies!
Sorry I should’ve mentioned the country I was in - I’m in the Netherlands (Amsterdam at the moment), then heading to Germany and Austria over next couple of weeks
really frustrating I can’t get it to work, think I’m gonna have to waste money and buy another SIM card!
- JJP2RidesAgain08-05-2024SMARTY Centurion
IF you can’t get it to work, and your phone is eSIM compatible, get a travel eSIM, which is data only, so you could use WhatsApp for calls and texts
You could try Airalo or Holafly - Plenty of videos on YouTube - search “Project Untethered” for some good explainer videos
- LaurenS_264377408-05-2024SMARTY Maverick
thanks for the suggestion - i've never used an e-sim but it looks like the phone has the option to add one. Will look into it!
- MSF08-05-2024SMARTY Guru
LaurenS_2643774 Provided that the iPhone is an XS or later, it should accept an Esim.
I recently used one and it worked extremely well. Just a tip - if you use Airalo, check for regional sims (i.e. Europe) rather than individual countries as this will save money. (Advice may apply to the other Esim providers, but I settled on Airalo so am not sure)
- PhilipC_217680320-06-2024SMARTY Maverick
This is apparently “the solution”
Thanks - yes absolutely that's the first thing i checked, to make sure roaming was switched on!
i've also tried manually selecting each of the 3 networks that come up, and it just keeps telling me i don't have internet.
Looks like i will have to get a non-smarty sim card so i'm not restricted to wifi
