EU roaming not working
- 08-05-2024
Thanks for all your replies!
Sorry I should’ve mentioned the country I was in - I’m in the Netherlands (Amsterdam at the moment), then heading to Germany and Austria over next couple of weeks
really frustrating I can’t get it to work, think I’m gonna have to waste money and buy another SIM card!
IF you can’t get it to work, and your phone is eSIM compatible, get a travel eSIM, which is data only, so you could use WhatsApp for calls and texts
You could try Airalo or Holafly - Plenty of videos on YouTube - search “Project Untethered” for some good explainer videos
