EU roaming not working
- 08-05-2024
I’m having exactly the same in Poland. Been on live chat for 2 days. Tried the sim in other phones - exactly the same.
I don’t understand what’s going on. I’m on an iPhone 15 Pro. Ive travelled with Smarty all over Europe (including Poland) before. It’s just not working.
after 2 hours on live chat I got a refund on my monthly package and got an eSIM which is working perfectly.
what a hassle though! Ive been a big smarty advocate- but I need something more reliable.
RoCoUK Not totally sure that it is fair to blame Smarty here. You say yourself that you have travelled all over Europe with a smarty sim and presumably you were happy with it.
Surely this is down to the local network(s) - I assume that you did a manual search and tried each in turn.
Wildcard idea......you're not anywhere near Ukraine where there may be congestion?
- PhilipC_217680320-06-2024SMARTY Maverick
I tried all networks in Dresden, nothing
in Vienna the day before was fine.
- RoCoUK13-06-2024SMARTY Maverick
Hey - it’s entirely Smarty at fault here. I have a vodafone corporate sim that works fine. The smarty sim in my other iPhone doesn’t work.
Ive tried the following:
- check the network settings
- disable 5g
- manual select network
- voda sim in my IPhone 15 - works
- smarty sim in my IPhone 14 - doesn’t work
- full network reset
- eSIM in my iPhone 15 - works
there is something wrong with the HLR at Smarty’s end.
I’m in the centre of Krakow and have never had an issue before.Anoop from live chat has been amazing. But it’s just not working.
