LaurenS_2643774
07-05-2024SMARTY Maverick
EU roaming not working
Any tips for getting EU roaming to work on an iPhone? I have followed the steps suggested on the smarty website (going to mobile data network and changing the mobile data/MMS APN to mob.asm.net. Roam...
- 08-05-2024
Tristan_3222814
23-04-2025SMARTY Enquirer
Total nightmare with Smarty in Berlin on an iPhone 13 - absolutely no signal despite checking all the settings- yet on my wife’s android phone no problems - what is the problem
- MSF24-04-2025SMARTY Guru
Tristan_3222814 Both on Smarty? Both in the same place? Both Roaming on the same network?
Have you tried swapping your sim to her phone to see if it works then? If it does, it will be a phone issue. You did turn on all Roaming settings definitely?
