EU roaming not working
- 08-05-2024
Thought I had got eu roaming although I found it very challenging.This is probably an age thing as I am in my eighties.As it did not work for me and I will have incurred out of plan charges I do not think Smarty is for me.
Disappointed
Eleanor_3457716 If you have not previously added any credit to your account, then you cannot incur any out of plan charges - so, no problem there!
EU Roaming sometimes requires you to manually select a network from those available until you find a strong signal - it's in the phone settings.
Did you also have roaming turned on in your settings? Did you follow Smarty's instructions for roaming?
