EU roaming not working
- 08-05-2024
thanks for the suggestion - i've never used an e-sim but it looks like the phone has the option to add one. Will look into it!
LaurenS_2643774 Provided that the iPhone is an XS or later, it should accept an Esim.
I recently used one and it worked extremely well. Just a tip - if you use Airalo, check for regional sims (i.e. Europe) rather than individual countries as this will save money. (Advice may apply to the other Esim providers, but I settled on Airalo so am not sure)
- JJP2RidesAgain08-05-2024SMARTY Centurion
Yes MSF LaurenS_2643774 All eSIM providers offer regional and also global bundles.
Most European regional eSIMs also include the UK, so any data left over after a trip to continental Europe isn’t wasted, as it can be used here in the UK.
