LaurenS_2643774
07-05-2024SMARTY Maverick
EU roaming not working
Any tips for getting EU roaming to work on an iPhone? I have followed the steps suggested on the smarty website (going to mobile data network and changing the mobile data/MMS APN to mob.asm.net. Roam...
- 08-05-2024
Katrina_1423832
11-09-2024SMARTY Pioneer
Ridiculous that Smarty cannot get its systems working for iPhones. I am having the same problems as you.
11-09-2024SMARTY Guru
Katrina_1423832 Why do you assume that it is Smarty's fault? When roaming, you are relying on one of the networks in the country you are in.
