EU roaming not working
- 08-05-2024
Rob_2282497 I must totally agree with JJP2RidesAgain here. I have roamed quite successfully with Smarty in many parts of EU with no problems. There are times when it pays to do manual network selection rather than auto.
When you use an Esim, why network are you on? Is it the same one as when EU Roaming on Smarty?
Doesn't the Esim purchase service from just one network in the country where you roam?
Hi MSF Travel esim providers do sometimes use multiple networks in a country.
Airalo’s UK eSIM uses a combination of both O2 and Three. If users buy their European eSIM, which includes the UK, EE is added to the list of available networks in the UK, and users can manually switch between the strongest network.
