โ19-09-2023
12:32 PM
- last edited on
โ21-11-2024
13:21 PM
by
JodieC
Does unlimited data mean unlimited or is there a cap usage you can use?
โ19-09-2023 14:50 PM
Unlimited does mean what it says on the tin, however it's also good to know that there is a section on "responsible use" within the T&Cs (which @Strandloper mentions) .. I have loosely extracted the bits that might be relevant:
- You must not use SMARTY Services .. for unsolicited bulk or commercial communications (relating to SMS)
- To download, send or upload content of an excessive size, quantity or frequency. Weโll contact you if your use is excessive;
- Our Unlimited Data Only SIM plans are for personal, non-commercial use only and can be used in SIM enabled tablets or laptops and portable mobile WI-FI devices and is uncapped for this use
- This SIM card should not be used as a permanent long-term alternative to home broadband.
+ a few other things, you can read more in the actual document here if interested. Service could be suspended without warning if usage is excessive, or if the terms are not adhered to.
โ19-09-2023 13:04 PM
In Smartys T&C's they say that unlimited is exactly that. They do have a "fair usage" policy (which we should all read) but that doesn't change the use of data AFAIK
โ27-02-2024 19:04 PM
I think you would have to be really hammering it to get noticed, say over 1000GB constantly over 4-5 months.
โ27-02-2024 17:34 PM
What amount is "excessive"?
โ27-02-2024 17:38 PM
@Jamie Not sure there is a definition of that. The thing is that they say they will contact you; this should give you a chance to explain ny unusually high usage.
โ18-03-2024 23:12 PM
I used a Smarty SIM in an external 5G router from October to February. I went over 1TB download twice, and other months was over 600GB. i didn't hear anything from Smarty (in fact I wasn't aware of the policy). I now have Fibre broadband.
โ13-11-2024 15:57 PM
Hi all unlimited data is just that no caps or fair use policy you can use as much as you like as long as it's personal use and your not using it as broadband on smarty unlimited really is unlimited you can use your data as a hotspot just not as a replacement for home broadband there isn't a cap so there isn't a number as to how much you can use
![](/skins/images/AAE85A3447F7AF7113C48835CFB16533/responsive_peak/images/icon_anonymous_message.png)
