โ15-09-2023
19:32 PM
- last edited on
โ18-09-2023
13:27 PM
by
Is there any way I can sort my Smarty SIM on my UK mobile so that I can send Texts back to a US mobile number? I am receiving messages but can't reply
- Labels:
Add-ons
โ15-09-2023 20:24 PM
You need to add some credit to your account. Texts to US numbers are chargeable.
โ13-06-2024 17:46 PM
The error message didn't come through immediately so - at first - it wasn't clear that it related to that. Additionally it was triggered by a group chat in which I couldn't tell that one of the participants was in the US (as iMessage on the Mac supports group messaging between iOS/Android users).
As for a more useful message I'd suggest:
"International texts aren't covered by your plan, please add credit to your account." and, ideally, add a link that actually goes to further information.
โ23-01-2025 07:23 AM
Hello, I have credit and still cannot send texts to certain numbers. It just says not sent. And gives a resend and delete option. I am an android user. Do you have a solution?
Thank you
โ23-01-2025 09:11 AM
@M_2017601 Certain numbers???????
โ23-01-2025 08:15 AM - edited โ23-01-2025 08:17 AM
@M_2017601 It would be helpful if you told us what kind of numbers these are.
If you mean short codes, Smarty doesn't currently support sending to these.
โ13-06-2024 17:49 PM
@ChrisKempt Doesn't iMessage work on data rather than SMS?
Your suggested text sounds fair enough - why not send it in?
โ13-06-2024 17:52 PM
Not if there are android users in the group, those users get SMS instead.
Where would I send it?
โ13-06-2024 18:15 PM
I don't know much about Adenoid users - interesting!
I would be inclined to send your suggestion initially as a complaint solely because I think that those bypass the Support Team (it's above their pay grade I think).
Nothing ventured, nothing gained!
โ13-06-2024 17:02 PM
This is the error I received which isn't helpful:
"Sorry, but we haven't been able to connect you to this service as it isn't included in your plan. To find out how to, go to https://go.smarty.uk/SMARTY/ZYMfDl
Also the link just takes you to the login page which isn't helpful either.
โ13-06-2024 17:16 PM
@ChrisKempt Once you log in at that page, you can purchase the necessary add on as you will be in your account.
โ13-06-2024 17:18 PM
Again, I understand that *now* but there's no way I could have understood that from the error message and when you login you're just taken straight to the dashboard.
โ13-06-2024 17:21 PM
@ChrisKempt Sorry, then it must be me! It says the service is not included in your plan - this indicates that you need credit to pay - and then takes you to log into your account, where you get the option to buy an add in.
I'm not sure how else they could put it really.
If you think of useful piece of text to replace the message, send it in as suggestion maybe.
Reply below:
โ13-06-2024 13:54 PM
Honestly, not super-impressed with this. The error returned is crazily vague, the link in it just goes to the account page and the resolution was far too hard to find.
โ13-06-2024 14:06 PM
@ChrisKempt The original post involves the OP trying to send a text to an INTERNATIONAL number. As that isn't included in any smarty plan, you need to add credit as an add on to pay for it. The cost of this type of call/text is given in the Price Guide.
If you are struggling to add credit to your account, have you tried the web page rather than the app? If there is still a problem, then you would need a web chat with the Support team so that they can check your account.
โ15-09-2023 20:30 PM
What @WelshPaul says.
Also, if you and the person(s) in the USA whom you are texting were to use WhatsApp, Signal or Telegram, the text messages would be free and only use a small amount of data.
โ15-09-2023 21:01 PM
Thanks...I use WhatsApp but the contact in US is an older lady and only uses. text so sounds like adding credit is the right way to go . Thanks
