Incoming calls go to Voicemail following port
Marmalade
Hi - i successfully ported my number to Smarty today. Outgoing calls show my number correctly, but incoming calls go to Voicemail at the callers end.
All is working ok now. Think that the port was not fully complete even though Smarty email 5 hrs ago said it was.
Thanks everyone for your help.
8 REPLIES 8
SmartyTrousers
@Marmalade Which voicemail - Smarty's or the old network's?
@Marmalade Perhaps worth trying a Network Reset on your phone first to ensure that yowling to the Smarty Network correctly.
If it persists, web chat with Smarty Support so that they can check for any problems in the port e.g. split port.
Marmalade
I have now restarted the phone and checked Call Forwarding is set to None. The Voicemail that the caller hears is from their network not Smarty. Incoming texts are also failing.
@Marmalade  That's why I mentioned the possibility of a split port. You need to web chat with Smarty Support for them to investigate.
@Marmalade And is that the network you have moved from?
That's difficult to say. I tried from a Giffgaff phone but that was also my previous provider. That was the only phone I had
@Marmalade 👍
