02-01-2023 04:17 PM
02-02-2023 11:16 AM
Just had a look through Amazon's offerings.
It looks like the terms "5G" and "budget" are not often seen together. Couldn't see anything much under about £330.
02-02-2023 12:39 PM
Yeah @Brookhouse like @MSF says there - 5G and budget are really rare, even with Android devices. If it is purely a backup then I would encourage you to have a look at some of the refurbished devices you can get nowadays, a lot of providers still offer a decent warranty with them and there is usually a chunk of the cost of the device.
02-03-2023 09:26 AM
What about the Honor 8X 5G, which I've subsequently found? It's £199.99. Any thoughts?
It's on the list of 5G phones that work with Smarty, but seems to have an older version of the operating system, and perhaps a bespoke version?
02-02-2023 02:17 PM
Have a look at the Google Pixel 6a.
This is a 5G handset, and should last you for 4-5 years.
Currently £399 in Argos (SIM Free), or directly from Google (with the option of 0% APR financing for 24 months at £16.63/month).
02-04-2023 12:34 PM
Oppo A74, £150 at Argos, £125 on eBay
02-04-2023 01:29 PM
Try www backmarket.co.uk
