Cheap Android phone with 5G and GooglePay
Brookhouse
I'm looking for a budget Android phone, just as a backup phone, that works with 5G on Smarty and supports GooglePay (maybe they all do?).
Any suggestions or preferences?
6 REPLIES 6
Just had a look through Amazon's offerings.
It looks like the terms "5G" and "budget" are not often seen together. Couldn't see anything much under about ยฃ330.
George
Yeah @Brookhouse like @MSF says there - 5G and budget are really rare, even with Android devices. If it is purely a backup then I would encourage you to have a look at some of the refurbished devices you can get nowadays, a lot of providers still offer a decent warranty with them and there is usually a chunk of the cost of the device.
Brookhouse
What about the Honor 8X 5G, which I've subsequently found? It's ยฃ199.99. Any thoughts?
It's on the list of 5G phones that work with Smarty, but seems to have an older version of the operating system, and perhaps a bespoke version?
Have a look at the Google Pixel 6a.
This is a 5G handset, and should last you for 4-5 years.
Currently ยฃ399 in Argos (SIM Free), or directly from Google (with the option of 0% APR financing for 24 months at ยฃ16.63/month).
RalphDa_1828705
Oppo A74, ยฃ150 at Argos, ยฃ125 on eBay
Michael_1855590
Try www backmarket.co.uk
