Tp-link M7350 settings
GaryRog_2222066
hi all,
Has anybody got the settings to setup a tp link M7350 4g lte router on unlimited data only plan? Having trouble with connecting xbox series s, S20 and win11 connects fine.
Thanks
5 REPLIES 5
This looks familiar, I think you have posted this before.
What you have to do is set the APN within the router to โ€˜mob.asm.netโ€™ (That is the setting you need)
What you need to do is read the tp-link manual, google it, or see if there is a video on YouTube.
You could of course also contact TP Link for support.
From the Smarty side, itโ€™s very easy, as mentioned above, you simply need to change the APN to โ€˜mob.asm.netโ€™
The TP-Link side of things is where it may not be easy, depending on how easy or not TP-Link allow users to alter settings.
@Well spotted my dear Watson!!!๐Ÿ”. Sorry I wasted my time replying!! Harumph!
Thanks all,
@GaryRog_2222066  As @Strandloper says, you may need the manual.
Basically, the standard procedure is to open the router's IP address in your browser and then change the APN to mob.asm.net
Strandloper
@GaryRog_2222066,
From a little research you'll find a downloadable users guide at the following link:
https://www.tp-link.com/uk/support/download/m7350/
