TPLINK M7350 - settings for EU Roaming
โ16-05-2025 16:53 PM
As Subject says... the page of Smarty settings for 'other' devices does not correspond with the fields available in the Dial Up settings page of my TPLink m7350 mifi Router. Specifically there is no mention of MMS anywhere.
The options I have are Name; PDP type; APN type [Static/Dynamic]; APN; Auth [none/CHAP/PAP]
What should I do to improve my chances of having a Data service available in Greece and Italy, please?
โ16-05-2025 17:27 PM
Apologies if it is Bad Form here to follow up one's own post.
On the basis that it is The Simplest Thing That Might Work I have setup and activated a new connection profile on my M7350 router in which the sole change was to update the APN from 'three.co.uk' to 'mob.asm.net'
I have restarted the mifi device and it is still connecting to the Three network via my Smarty SIM in the UK, and I am sending this update via that connection.
If anyone knows that this will NOT be sufficient for data Roaming in Greece and Italy could you alert me, please?
