SIM card not connected ring whilst in France and I have changed the apn. Very frustrating
AliceFin_432121
9 REPLIES 9
Matthew_1262773
Do you have to change the APN back once you return to the UK?
@Matthew_1262773  Just to confirm what @JJP2 says - no, you do not need to do anything when you return and also you will not need to do anything if you Roma in the future with the same phone. It's a one-off process.
Ah that’s good to know thanks for the reply, much appreciated 👍🏼👍🏼
No, you can leave it as “mob.asm.net” in the UK and your phone will work fine
Thank you 😊 much appreciated
@AliceFin_432121 Is there any chance that you were somewhere remote with no signal?
Can you check the sim in another phone?
Thank you for your help. I tried information I received directly from Smarty but it did not work but your suggestion to put in a phone did the trick. I then inserted card back in wifi router and we now have wifi abroad !  Thank you.
@AliceFin_432121   Good news!
@AliceFin_432121 Forgot to say......have you tried manually selecting one of the networks that show, rather than letting the phone auto-select?
