SIM card not connected ring whilst in France and I have changed the apn. Very frustrating
AliceFin_432121
9 REPLIES 9
@AliceFin_432121 Is there any chance that you were somewhere remote with no signal?
Can you check the sim in another phone?
@AliceFin_432121 Forgot to say......have you tried manually selecting one of the networks that show, rather than letting the phone auto-select?
Thank you for your help. I tried information I received directly from Smarty but it did not work but your suggestion to put in a phone did the trick. I then inserted card back in wifi router and we now have wifi abroad !  Thank you.
@AliceFin_432121   Good news!
Matthew_1262773
Do you have to change the APN back once you return to the UK?
No, you can leave it as “mob.asm.net” in the UK and your phone will work fine
Thank you 😊 much appreciated
@Matthew_1262773  Just to confirm what @JJP2 says - no, you do not need to do anything when you return and also you will not need to do anything if you Roma in the future with the same phone. It's a one-off process.
Ah that’s good to know thanks for the reply, much appreciated 👍🏼👍🏼
