โ05-06-2023 20:15 PM
โ06-09-2023 06:50 AM
Do you have to change the APN back once you return to the UK?
โ06-09-2023 09:12 AM
@Matthew_1262773 Just to confirm what @JJP2 says - no, you do not need to do anything when you return and also you will not need to do anything if you Roma in the future with the same phone. It's a one-off process.
โ06-09-2023 11:46 AM
Ah thatโs good to know thanks for the reply, much appreciated ๐๐ผ๐๐ผ
โ06-09-2023 07:27 AM
No, you can leave it as โmob.asm.netโ in the UK and your phone will work fine
Thank you ๐ much appreciated
โ06-06-2023 08:45 AM
@AliceFin_432121 Is there any chance that you were somewhere remote with no signal?
Can you check the sim in another phone?
โ08-06-2023 20:48 PM
Thank you for your help. I tried information I received directly from Smarty but it did not work but your suggestion to put in a phone did the trick. I then inserted card back in wifi router and we now have wifi abroad ! Thank you.
โ09-06-2023 07:37 AM
@AliceFin_432121 Good news!
โ06-06-2023 08:46 AM
@AliceFin_432121 Forgot to say......have you tried manually selecting one of the networks that show, rather than letting the phone auto-select?
