Porting problem
โ06-04-2023 11:27 AM
Hi i ported my number to smarty now my account is not working dashboard showing Account Closed I cant log into account as verification code is sent to old number Not available as New number is not shown contacted live chat are useless cant answer questions its been 20 minutes and they havent replied to my last comment TOTAL DISASTER 3 agents i spoke to no one has Helped 3 months ago i ported a different number i spent 4 weeks with the same problem never got resolved ended getting PAC code and Leaving when you have problems no one at Smarty can Help
โ06-04-2023 11:33 AM
Also when i submitted my PAC code it wasn't excepted received 10 emails same day your port was not completed?
โ06-04-2023 11:45 AM
im 1 hour on chat still cant answer question how do i contact the porting Team for support its like banging your head against the wall painful 15-20 minutes for useless replies use your number to login
โ06-04-2023 12:16 PM
1 Hour 30 minutes no replies or help on chat i given up Totally Unacceptable
โ06-04-2023 12:23 PM
You are blessed to log into your account to post here? Is there no number showing on the dashboard then?
โ06-04-2023 12:24 PM
Sorry for typo above - won't edit!
You are logged in so that you can post here?
โ06-04-2023 12:28 PM
Hi I'm loged in but dashboard shows account closed and old number not new number last reply from smarty support 40 minutes ago are you still their no help at all 1 45 minutes on chat
โ06-04-2023 13:02 PM
You could ask your web chat agent to transfer your chat over to the team supervisor, which will need some insistence from your side.
In my experience, the web chat agents often seem to follow a script, without necessarily reading your posts to address the issues.
โ06-04-2023 15:03 PM
yes asked 4 times how to contact porting Team didn't even answer my question they dont even read my questions
โ06-04-2023 15:28 PM
I don't know of any UK mobile network operator that will let you speak to their porting team @AB.
Did you ask the support team agent to be transferred to the web chat team supervisor?
โ06-04-2023 15:07 PM
When was the port due to happen? What date??
โ06-04-2023 18:50 PM
Hi ported in on Tuesday afternoon
โ07-04-2023 16:18 PM
Hi @AB sorry to hear you're having these issues. Have you ported this number from one SMARTY account to another? If so this could be what's causing the issue. However, please stick with the customer support agent you're speaking to as they will get to the bottom of it and fix it for you.
โ08-04-2023 12:06 PM
i ported in from Lebara vodafone
โ08-04-2023 12:11 PM
i had this number with smarty in December and had the same problem so I ported out
โ09-04-2023 12:52 PM
Lebera seem to be using a range of mobile numbers, which can causes issues with some UK network providers. For example, iD Mobile recognise some Lebera numbers a premium rate mobile numbers.
Perhaps SMARTY recognise the number you've tried to port from Lebera, as belonging to SMARTY Mobile already, which might explain the problem here.
โ10-04-2023 11:25 AM
Im waiting on support to get back to me Tuesday but was already promised 24/48 Hour reply which didn't happen not holding my breath that this will be fixed i would like to stay with smarty but asked for Pac code which smarty agent didn't provide he said wait till next week till we fix the issue
โ11-04-2023 15:11 PM
My situation is still not resolved NOW i cant even get a PAC Code to leave smarty
โ13-04-2023 09:52 AM
That really does not sound good!
Details of complaints process: https://smarty.azureedge.net/files/SMARTY-Customer-Complaints-Code.pdf
โ13-04-2023 11:40 AM
I have raised a complaint no reply yet 2 Days a go not holding my breath
โ13-04-2023 12:09 PM
Use https://www.resolver.co.uk/ to file a complaint - It's Free.
โ13-04-2023 18:47 PM
Thank God I managed to Port out Today
Now with new network got my number back all is working Smarty you and your support are a shambles and disgrace i wanted to stay but 14 days issue not fixed agents couldn't get any replies from Tech Team
they did refund me my 1st month payment that's something im glad the Pac code worked as agent advised the Pac code wasn't going to work
Goodbye Smarty
โ13-04-2023 22:46 PM
Appears to be a clear case of #MoreMalarkey, #LessSMARTY.
โ17-10-2023 11:11 AM
@AB Did the issue resolve for you? How long did it take? Smarty messed up by switch as well. I moved to smarty from giffgaff and now can't use my number. What did you do to resolve your issue?
