12-09-2023 11:16 AM
Hello! 2 weeks ago I have decided to give SMARTY a try and ported my old phone number from Vectone. Since then I can only make and receive phone calls, but can't send or receive SMS text messages. After trying all the guides I could find on the website nothing worked so I contacted support via the live chat. They were extremely unhelpful, asked me the same questions over 3 times now and then leave me waiting. I need to fix this urgently since this is my number that I use for 2FA in all websites and most importantly Universal Credit that I must have access to at all times or could get into very serious trouble! I am using Android and would be very thankful for any help on this. Thank you!
12-09-2023 11:21 AM
@xYorYx Does this apply to all text messages, or is it linked to short-code texts? The problem is that Smarty does not support short-code text service.
12-09-2023 11:21 AM
12-09-2023 11:24 AM
I don't have a friend with UK number to test that, but does no short-code texts mean I cannot use SMARTY for 2FA? I have tried with Universal Credit and OFX and not receiving the verification code from either
12-09-2023 11:40 AM
@xYorYx Basically, within a Smarty plan, you can only send a text to a standard UK number. Some organisations do use a standard number to send you a verification code and that works just fine - as an example, smarty do that and so do Santander - there are many others.
I really don't know about DWP and UC though.
I am also assuming that you are using the smarty plan in the Uk and are not Roaming.
12-09-2023 12:35 PM
Yes I am in the UK. Is there any information when/if they will add short texts?
12-09-2023 12:54 PM
@xYorYx Unfortunately not. This topic rears its ugly head quite frequently and the answer is always "we're working on it" or words to that effect.
12-18-2023 04:25 PM
I have the same problem after porting in my number from 02, I currently canotr recive incoming calls text or varification codes. Its been 7 days my life has been on hold, all i get from live chat is we are working on it
12-18-2023 04:27 PM
I have the same problem after porting my number from 02,
Cant recive calls texts or codes, life is on hold for 7 days and live chat just tells me they are working on it with no timeframe of a responce from the team who deal with this issue
12-18-2023 05:38 PM
@Izzy-DiOne I have just responded to your message on another thread.
If you need to message to a short code number, then you cannot currently do that on Smarty. You can only send a text to a standard format UK mobile number.
