xYorYx
09-12-2023SMARTY Maverick
Not receiving 2FA texts after porting
Hello! 2 weeks ago I have decided to give SMARTY a try and ported my old phone number from Vectone. Since then I can only make and receive phone calls, but can't send or receive SMS text messages. Af...
Izzy-DiOne
18-12-2023SMARTY Pioneer
I have the same problem after porting my number from 02,
Cant recive calls texts or codes, life is on hold for 7 days and live chat just tells me they are working on it with no timeframe of a responce from the team who deal with this issue
18-12-2023SMARTY Guru
Izzy-DiOne I have just responded to your message on another thread.
If you need to message to a short code number, then you cannot currently do that on Smarty. You can only send a text to a standard format UK mobile number.
