26-01-2024 14:13 PM
Good afternoon all.
I have a Samsung S23 Ultra, and i have noticed that lately the codes that you would use for say
"getting your imei code" *#06# has stopped working for me
Usually when you dial into your phones keypad it would immediately bring up your phones IMEI Number, but this is not the case for me, and even if you type it in and press the "dial button" i am presented with a message which says "USSD CODE RUNNING", followed by " CONNECTION PROBLEMS OR INVALID MMI CODE"
Having googled this, and tried various solutions, i am no further forward.
Most things point to Network issues or Sim card issues, but i am using my phone with none of these problems
I have also tried resetting network settings,airplane mode on/off fix,tried running in safe mode incase of app issues,adding an extra prefix code, swapped the sim card to sim tray 2, but to no avail.
If anyone could advise if they have ever run into this issue, or could offer some guidance on a fix.
Thanks
Tom
29-01-2024 16:16 PM
Isn't the device's IMEI number shown in various other places in the Android settings app, @THOMAS-P.
What happens if you search for IMEI on your S23 Ultra?
29-01-2024 16:47 PM
Yes it is. I am only using this code as an example as it's the most commonly known one. There are dozens of short codes that can be used, but I am unable to use any due to this ongoing issue.
Thanks
30-01-2024 14:51 PM
I'm not an Android handset user, but the *#06# short-code works with my SMARTY SIM card in my iPhone.
What've Samsung advised about their S23 handset, and the processing of GSM short-codes, @THOMAS-P?
30-01-2024 15:49 PM
Hi,
Nearly all these short codes are universal across all networks and handsets.
Samsung
Without in-house analysis of the handset, could only advise of a possible software glitch, but advised more than likely it's related to Network settings / Network signal / or issues with the Sim card.
Friends with the same handset are not experiencing the same issues as I have, but none are on the smarty network.
If they lived locally to me I could have tried my SIM in their phone to see if the issue is possibly "SIM related".
What am hoping for is another user on the forum with the same handset, and obviously on the smarty network to check to see if they are having any issues themselves.
Last resort is a complete wipe and reinstall of the current operating system
Thanks
30-01-2024 17:07 PM - edited 30-01-2024 17:26 PM
Do correct me here @THOMAS-P, but my understanding is an USSD / MMI code is interpreted by the handset first; thereafter, the corresponding command is sent to the operator's network.
I've tried the *#21**11#, *#30#, and *#31# shortcodes, but none of these worked - although I've used the #31# shortcode to hide my number, on more than one occasion.
Perhaps my handset isn't generating the correct commands, or maybe the MVNO SMARTY Mobile only provide limited support for USSD / MMI codes.
30-01-2024 23:01 PM
Your absolutely right in this regarding your phone interprets the command,which in turn is interpreted by the mobile network.
It's making me wonder if it's just down to smartys network setup not having the support for this .
A will try and pick up a payg SIM card from a major network to test this theory
31-01-2024 12:32 PM
Hey @THOMAS-P, I saw somewhere online a mention that USSD / MMI can be problematic when you're using a dual SIM capable handset. Could this be true?
Hopefully your experiment with a PAYG SIM will be insightful.
05-02-2024 20:34 PM
No joy with EE PAYG sim card on this.
Will head back to Samsung customer support, as i cant figure this out
