THOMAS-P's avatar
THOMAS-P
USSD / MMI CODES NOT WORKING
Good afternoon all.
I have a Samsung S23 Ultra, and i have noticed that lately the codes that you would use for say
"getting your imei code"   *#06# has stopped working for me
Usually when you dial into your phones keypad it would immediately bring up your phones IMEI Number, but this is not the case for me, and even if you type it in and press the "dial button" i am presented with a message which says "USSD CODE RUNNING", followed by " CONNECTION PROBLEMS OR INVALID MMI CODE"
Having googled this, and tried various solutions, i am no further forward.
Most things point to Network issues or Sim card issues, but i am using my phone with none of these problems
I have also tried resetting network settings,airplane mode on/off fix,tried running in safe mode incase of app issues,adding an extra prefix code, swapped the sim card to sim tray 2, but to no avail.
If anyone could advise if they have ever run into this issue, or could offer some guidance on a fix.
Thanks
Tom
  • Chalkychap's avatar
    Isn't the device's IMEI number shown in various other places in the Android settings app, THOMAS-P
    What happens if you search for IMEI on your S23 Ultra?
    • THOMAS-P's avatar
      THOMAS-P
      Yes it is. I am only using this code as an example as it's the most commonly known one. There are dozens of short codes that can be used, but I am unable to use any due to this ongoing issue.
      Thanks
        I'm not an Android handset user, but the *#06# short-code works with my SMARTY SIM card in my iPhone.
        What've Samsung advised about their S23 handset, and the processing of GSM short-codes, THOMAS-P
