saying PAC is wrong
Options
โ03-08-2023 05:59 AM
When i enter the pac number given by my old provider it is saying it is wrong, not sure what to do
Options
โ03-08-2023 08:54 AM
One suggestion would be to contact your old provider and get them to check the pac you've received.
You'll probably need the IMEI of the phone you used with the old provider (use *#06# to get the IMEI ).
Options
โ03-08-2023 09:06 AM
@Danielle_326456 Is it, by any chance, over 30 days old? They expire after that time.
