iPhone won’t ring out
Options
10-07-2023 11:31 AM
Hi my iPhone 6 with 2 gig smarty sim won’t ring out but can receive calls, any suggestions would be appreciated
Options
10-07-2023 13:17 PM
What do you mean by 'won't ring out'? Are you saying it's receiving calls, just not making a sound? If so, do you have the switch on the side set to mute (showing the orange colour)?
Do you mean you can't make outgoing calls? If so, what exactly happens when you try to?
Options
14-07-2025 16:08 PM
Message just said cannot connect
