iPhone won’t ring out
DavidSe_1278950
Hi my iPhone 6 with 2 gig smarty sim won’t ring out but can receive calls, any suggestions would be appreciated
1 REPLY 1
SmartyTrousers
What do you mean by 'won't ring out'? Are you saying it's receiving calls, just not making a sound? If so, do you have the switch on the side set to mute (showing the orange colour)?
Do you mean you can't make outgoing calls? If so, what exactly happens when you try to?
