Home portable router
JuanMat_1657689
Hi there I need a portable home router , always I'm tethering hotspot with my smartphone, any suggestions ?
3 ACCEPTED SOLUTIONS
Jomac
Just look on eBay for an unlocked 4G Router, you should be able to pick one up for well below ยฃ30 THREE network who own Smarty and share the same network supply a free router,
MikeHorn_626296
I use a 4g ZTE router bought of Amazon for ยฃ35 works fine
SimonGuru
Hi my recommendation is a TP-Link TL-MR6400. This is a 300Mbps 4G mobile wi-fi router with SIM slot unlocked to all networks and no configuration required. It also has removable external wi-fi antennas.
30.00 and a very good make and you can control it with the TP-LINK APP And TP-Link TetherApp
I Have this one and it has amazing reviews and a good price or if you have any routers or modems sitting around your house by any isp supplying organisation then use that in bridge mode and use it as a range extended or a modum on its own
Regards Simon
Regards
Simon
22 REPLIES 22
DanielP_2058417
Be careful buying tp link. Lots of people either cant get them working at all with smarty or like me i can only get 3g. 4g seems to be blocked. In my phone it gets 500mbps but only 3mbps in the expensive router lol
Ok i did a factory reset and now its working at 100mbps.
I wonder if my new item from currys was a previous return and had some settings changed as it had some marks on it.
https://ibb.co/r5zHpMzhttps://ibb.co/r5zHpMz
Which router do you use then?
SimonGuru
TP-Link 300 Mbps 3G/4G Single-Band Wi-Fi Router, 1x 2.0 USB Port, 5x Fast WAN/LAN Ports, Connect up to 32 devices, WPS Button, No Configuration Required, UK Plug (TL-MR3420)
They changed the model number so this might be why you couldn't find it it's has over 30 k reviews
Regards
Simon
SimonGuru
Regards Simon
Regards
Simon
Struggling to find this at ยฃ30, Can you advise where you found it at that price?
That's inflation for you... +10% per annum.
Perhaps @SimonGuru acquired their's pre-owned.
Link below ยฃ26.70
Regards
Simon
MikeHorn_626296
Mine's a ZTE as well, very nice, cheap and simple to set up and customise.
Hi there, I have bought a ZTE router and put the Smarty sim in - but I am not finding the network with devices - please can you tell me how you did that? Thanks
@JaneSta_2609973  First thing is to ensure that the APN is set to mob.asm.net
You do this via the settings page for your router. Usually, you can type in 192.168.1.1 or similar into the address bar of your browser and it should bring up the page. Normal settings for username and password are admin and admin.
Jomac
Peto_Peter
Yeah but are you willing to keep removing sim card btw phone and router ? I was thinking same but was asking my self why when u have phone as router already ..
I was checking 5G WiFi 6 mobile routers a they cost like 200 or 300 or more so no point
Jomac
For what it costs Peto, I have two Sim card contracts, one for the router which is unlimited everything and a basic Sim for the phone, so no swapping needed. Other than general surfing on the phone, the only thing that would use expensive data would be Google Maps and even they can be preloaded into your phone before a journey. Using a basic Sim with limited data, I have never come close to using anywhere near my limit and never had to swap Sim's
Peto_Peter
Why would u pay twice?? person need just one sim and one payment !
So u bought expensive acces point ? how much ?
the_owl_0v0
Assuming "portable home router" means a home router connecting via the mobile network, I can suggest the Huawei H112-370 for use in the UK.
In Leicestershie I'm currently getting ~600Mb/s down and 32 Mb/s up on both Ethernet to my laptop and and WiFi 6 to my phone (Ookla speed test at time of writing this response)
Hope this helps.
MarkWeatherill
Hi, I have a couple of 4GEE 'mifi' routers, the bigger ones have good battery life, are fairly cheap second hand and if needed can be unlocked easily. I find they do freeze up occasionally but very useable and of course, portable.
Hello, how did you unlock? I phoned EE and they wouldnโ€™t allow me to unlock it, they wanted me to buy an EE data plan
Unlock codes are available from third parties on eBay, for example.
One of my 4GEE mobile routers has just failed, sadly. I replaced it with a BT mini hub.
@MarkWeatherill Don't forget that, if a device is outside of contract, the original network are obliged to unlock it free.
