Home portable router
- 20-12-2022
Just look on eBay for an unlocked 4G Router, you should be able to pick one up for well below £30 THREE network who own Smarty and share the same network supply a free router,
- 14-01-2023
I use a 4g ZTE router bought of Amazon for £35 works fine
- 15-01-2023
Hi my recommendation is a TP-Link TL-MR6400. This is a 300Mbps 4G mobile wi-fi router with SIM slot unlocked to all networks and no configuration required. It also has removable external wi-fi antennas.
30.00 and a very good make and you can control it with the TP-LINK APP And TP-Link TetherApp
I Have this one and it has amazing reviews and a good price or if you have any routers or modems sitting around your house by any isp supplying organisation then use that in bridge mode and use it as a range extended or a modum on its own
Regards Simon
Be careful buying tp link. Lots of people either cant get them working at all with smarty or like me i can only get 3g. 4g seems to be blocked. In my phone it gets 500mbps but only 3mbps in the expensive router lol
Which router do you use then?
