03-05-2023
04:55 AM
- last edited on
14-07-2023
13:38 PM
by
I have a redmi note 11 which only has the option of International roaming. It then says I will be charged. Smarty says EU I can continue to use my UK data. I'm in Italy and am without connection when I'm away from WiFi. Can anyone advise please? I have followed instructions to the letter.
03-05-2023 09:16 AM - edited 03-05-2023 09:19 AM
Okay @AngelaT_1873043, if you've got an active SMARTY plan, then you'll be able to use your plan's allowances while roaming in an EU destination like Italy.
Calls and texts will work without you needing to do anything, but using your mobile data while roaming requires the APN value to be "mob.asm.net", and data roaming enabled on your handset.
The following online instructions could help with the APN change:
https://smarty.co.uk/roaming-setup
See more about EU roaming online at https://smarty.co.uk/roaming.
03-05-2023 10:09 AM
Hello @AngelaT_1873043 . Have you by any chance already used up 12Gb of data while roaming? Anything in excess of that requires a data pass which is chargeable - https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf
11-09-2023 16:39 PM
It has annoyed me is time, I have never had to do anything other than turn on the roaming. This time a new setup that doesn't give me data, and I haven't used my data cause it renew before I got on the plane and have not been able to use it. The wifes phone is working fine , she doesn't have to ask every bar or restaurant for their Wifi code.
12-09-2023 15:47 PM
All you have to do is simply change the APN in your phone to ‘mob.asm.net’, it takes about 30 seconds.
You can use up to 12 GB of data within the EU. You will need an add on to use more than 12 GB or if you are travelling outside the EU.
Instructions on how to do this for both iPhone and Android are pinned at the top of the “FAQ” section of this forum.
