Firewall and Port settings
โ26-04-2024 13:04 PM
What are the router firewall and port settings for a Smarty 4G USB dongle? Thanks
- Labels:
Network
โ27-04-2024 16:13 PM
You cannot port forward on a SMARTY connection. SMARTY use CGNAT!
โ26-04-2024 14:20 PM
@RobertW_1360264 What is suggested in the product manual or online support document?
โ26-04-2024 13:10 PM
This is the Smarty community forum, we are customers just like you.
You would probably need to contact Smarty support.
Also, bear in mind that if you planning to use Smarty for commercial use, that contravenes section 5.15 of their terms and conditions below, so you may find your service suspended :
https://cdn.smarty.co.uk/files/SMARTY-Terms-And-Conditions.pdf
