โ02-08-2024 10:53 AM
I'm unable to call a Sipgate(voip) landline number from my smarty mobile.
โ02-08-2024 04:03 PM
Thanks for that, thought that might be the case but I couldn't find what the charge is.
โ02-08-2024 11:23 AM
@RichardBr_81563 Is it an 01, 02 or 03 UK number?
โ02-08-2024 02:51 PM
None of those, it's 056.
โ02-08-2024 03:41 PM - edited โ02-08-2024 03:42 PM
Unfortunately, that number would not be covered by your plan's calls allowance, @RichardBr_81563.
You'd need an add-on to cover out-of-plan charges, such as calls to 056 prefix telephone number/s.
โ02-08-2024 04:05 PM
@RichardBr_81563 Price Guide: https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*2j43s7*_ga*MTQyODM5MzM2Mi4xNzA1MzI3Mjcy*....
p.10 Left hand column
โ02-08-2024 05:42 PM
I've solved this issue and it maybe of interest to others. Sipgate my voip provider allow me to have a UK landline number (01) for free in addition to my existing number, this works!
