CALLS TO A VOIP NUMBER
RichardBr_81563
I'm unable to call a Sipgate(voip) landline number from my smarty mobile.
RichardBr_81563
Thanks for that, thought that might be the case but I couldn't find what the charge is.
6 REPLIES 6
@RichardBr_81563 Is it an 01, 02 or 03 UK number?
RichardBr_81563
None of those, it's 056.
Unfortunately, that number would not be covered by your plan's calls allowance, @RichardBr_81563
You'd need an add-on to cover out-of-plan charges, such as calls to 056 prefix telephone number/s.
RichardBr_81563
I've solved this issue and it maybe of interest to others. Sipgate my voip provider allow me to have a UK landline number (01) for free in addition to my existing number, this works!
