Text message problem
- 28-12-2022
You may need to check the settings on your phone. It should show 'My Number' somewhere (depends if iPhone or Android) and you should change it to show the correct number.
It is sometimes incorrect as the phone picks up the number from the sim when you insert it - in this case it is possibly the number that came with the sim and it did not register when you transferred your own number over to the phone (because the sim didn't physically change).
Hope this helps.
I have the same problem and I can't change the number in Facetime or Imessage, do I need a new SIM?
it should just be a setting issue, if you try the below it should help
Update your phone number:
- Go to Settings > Name, Phone Numbers, Email > Contactable At
- Choose Edit
- Enter your chosen number, using +44 instead of the first 0
- Tap Save
Reset iMessage settings:
- Go to Settings > Messages
- Toggle iMessage to OFF and then back to ON
- Once iMessage has been activated, scroll to Send & Receive to check if the right mobile number is ticked
Reset FaceTime settings:
- Go to Settings > FaceTime
- Toggle FaceTime to OFF and then back to ON
- Once FaceTime has been activated, scroll down and check if your mobile number is ticked under You can be reached by FaceTime at
- ChrisTo_215610811-07-2023SMARTY Rookie
I have done this and turned off phone and back on again and it makes no difference, iMessage does not work. The number is correct as I have checked this also.
- Michael_196041317-04-2023SMARTY Pioneer
There is no option in setting to change my phone number it just says unknown
- Christi_221416211-08-2023SMARTY Pioneer
I'm having the same problem as you having just moved over to smarty, my calls are going out on my old number but texts on the SIM card number and mine is showing as unknown too. Very confusing.
Mine is android.
- AlecEdworthy17-04-2023SMARTY Commentator
Do you have an iPhone or Android?
Kind regards, Alec
