10-02-2023 21:27 PM
How do i increase my internet speed?
17-02-2023 19:18 PM
Hello,
If your device is set to automatic selection of 3G / 4G then it could be hanging on to a weak 4G signal when you'd be better off using 3G.
If your device allows you to set it to use '3G only' try that.
13-02-2023 16:46 PM
This will vary from place to place. Unfortunately, you cannot guarantee where it will be fast. Often it is better to use a solid wifi connection.
11-02-2023 23:28 PM
Get a 5G capable handset, if you don't have one already.
