02-09-2024 08:11 AM - last edited on 02-09-2024 11:04 AM by YulianK
02-09-2024 10:27 AM
@davidma_1452134 You need to check the the router APN is set to mob.asm.net.
You will need to get into the Settings for the router - perhaps check the manual. Sometimes you can input 192.168.1.1 into the browser url bar plus the username and password for the router and then change it - depends upon the brand.
05-09-2024 04:00 PM
Took the sim out of the .mobile router, put it in my phone to set the apn, but still no good. Thanks
05-09-2024 07:38 PM
@davidma_1452134 I don't expect it would be because the device (in this case your router) needs to have the correct APN.
What you describe has only set the correct APN for the phone - it does not reside on the sim.
06-09-2024 07:31 AM
Thanks. Being a bit thick, how can I change it on the router? Where the interface for me to enter it? As you can tell, I'm not very good with this stuff.
06-09-2024 10:06 AM
@davidma_1452134 I did give you that info on 02/09/2024 at 10:27 above.
The interface is your browser and you need to input the setting that takes you to the router home page. I explained that it comes in the format of 192.168.1.1 but those numbers may not apply in your situation - you need to read the user manual to find out.
