06-02-2024 15:11 PM
Just joined Smarty with my Samsung A34 5G dual sim.
Wifi calling works with both sims simultaneously and 5G on both simultaneously, one is on EE and the other is Smarty.
There does seem to be an issue with Smarty going onto wifi calling, it seems to prefer to use the cellular network if the signal is good. You can force this by going onto airplane mode and manually switching on wifi while airplane mode is still on, and wifi calling comes on instantly. Not the best, will see how it goes when my number is ported over and have a chance to use it properly. Just got to switch off my voicemail now.
06-02-2024 15:31 PM
09-02-2024 14:18 PM
You are correct, the prefer wifi calling option I had with the EE sim has gone with Smarty. Although I do get a better cellular service now so it shouldn't be an issue.
The other issue I had when my number was ported was the phone number tied with the sim remained with the original number, but as others have done, I fitted the sim into an old iPhone 6 and went to conacts, and that has updated it.
28-03-2024 19:18 PM
It is a pity that Smarty don't implement the calling preference option between WiFi and the mobile network like other providers do.
18-11-2024 10:38 AM
I'm having trouble with Callers being instantly sent to Voicemail when phone is on Wifi Calling
I am missing calls for a Hospital appt (a Private No, so I can't call back) - Grrr!!
Must I have Mobile Data on? I'm in a very weak signal area and inside the house, but have good wifi 20MB/sec
Samsung A54 5G
18-11-2024 11:51 AM
@GrahamS_1507134 Not sure why mobile data will affect calls or texts.
18-11-2024 13:02 PM
No, no need for mobile data to be on for WiFi calling to work.
19-11-2024 08:54 AM - edited 19-11-2024 08:59 AM
There is an easy solution to make sure you have wifi calling working when you want it, such as at home. Just put your phone into airplane mode and then turn WiFi back on again. As there is no mobile data connection, WiFi calling is the default, and only connection method. If you have mobile data and WiFi calling on and there is the slightest of mobile data signal, then the phone will not use WiFi calling. You have to make sure that there is absolutely no mobile signal for WiFi calling to be activate. Don't forget to get out of airplane mode when you go outside though.
19-11-2024 13:10 PM
As above, I'm worried that a caller was sent to voicemail when I was at home with WiFi calling & internet active. Can any of you gurus suggest reasons why that could happen?
I'm in a dark hole for mobile signal, so Wifi calling is essential to me
Many thanks for yr replies above
20-11-2024 00:50 AM - edited 20-11-2024 00:51 AM
If there is any mobile signal available, even if you have WiFi calling on, you will not get WiFi calling (unless you are using an iPhone as they seem to work differently). To guarantee WiFi calling when at home, you have to turn airplane mode on and then turn WiFi on again which leaves mobile data off. Then you will get WiFi calling.
