04-04-2023
18:17 PM
- last edited on
17-07-2023
14:41 PM
by
05-04-2023 12:30 PM
You should have no trouble roaming in Spain generally. Coverage is usually quite good as the Spanish (just like the Brits) are glued to their mobile devices.
There are a number of networks - Movistar and Vodafone crop up frequently.
Don't forget that you will have a limit of 12Gb data on any smarty plan unless you buy a Data Roaming Pass.
09-11-2023 17:57 PM
Very poor
10-11-2023 10:27 AM
@StacyBa_2355411 May be worth turning off the auto-network feature on the phone and trying each of the manual selection in turn to see which is the best network locally.
