Roaming in Benidorm
Betty_Swollox
Anyone on smarty been roaming in Benidorm ? If so what's the coverage and speeds like ? Thanks 😁
You should have no trouble roaming in Spain generally. Coverage is usually quite good as the Spanish (just like the Brits) are glued to their mobile devices.
There are a number of networks - Movistar and Vodafone crop up frequently.
Don't forget that you will have a limit of 12Gb data on any smarty plan unless you buy a Data Roaming Pass.
StacyBa_2355411
Very poor
@StacyBa_2355411 May be worth turning off the auto-network feature on the phone and trying each of the manual selection in turn to see which is the best network locally.
