Phone connection
Russell_1907313
When i call someone on smarty network, i can here the ringing on my phone but the receipeints phone does not ring out
6 REPLIES 6
First quick options - turn phone off and remove sim for cleaning gently then re-insert and turn on again.
George
Hi @Russell_1907313 can you contact our team smarty.co.uk/contact so they can look into this for you?
Team does not exsist smarty.co.uk/contact
Try the bottom right hand corner blue circle on that page to start a web chat.
SoniaCu_2627934
Hi Russell,
was your problem solved as I am finding this happening often!!
