08-03-2023 16:53 PM
I used the pac code but smarty said there was a problem transferring my old number. I've checked with my old network provider and it is correct? Help please.
20-06-2024 19:07 PM
I've tried 4 times, twice over customer service and my issue is still not resolved. I'm going do give one last attempt, then move all 3 nos. I've got out from Smarty. Not worth the pain.
14-03-2023 20:33 PM
I have requested a STAC, it didn't mention i couldn't use my PAC to bring my number over help
15-03-2023 10:48 AM
If you have used the STAC, then you have cancelled the old number and so it will not transfer across.
You may need to check this with Support via web chat.
14-03-2023 22:35 PM
What are you trying to do @Anthony_1929657?
Leave SMARTY and keep your mobile number, or join SMARTY and keep your old provider's number?
If you've already used a STAC, you'll need assistance from the mobile network that gave you your STAC.
08-03-2023 17:49 PM
It's worth having a web chat with the Support Team so that they can take a look at your account to see what happened.
08-03-2023 17:27 PM
I had the exact same problem when I was using a pac to bring my number to smarty. All I could do was ask them to resubmit it complete the whole process again and the second time it went through. The network is worth it though since I’ve been using them no problems.
just to recap it needs to be resubmitted as if the first time never happened
