01-20-2024 01:33 PM
I was told that I should change my APN setting or I can not use smarty service outside UK by smarty.co.uk when I login my account. However, I can not find the APN setting in my iphone 14. I ask Apple service. It said I sould ask service provider if i can not find APN setting in iPhone.
And I do not know smarty service number.
Please help? Thanks a lot
01-20-2024 08:09 PM
Also found in the help article that Smarty give you: https://help.smarty.co.uk/en/articles/1155220-using-the-internet-after-you-ve-joined-smarty?_gl=1*m8....
01-20-2024 08:08 PM
@anqizha_2491732 Try Settings > Mobile Service > (Three) Mobile Data Network > (MMS) APN
(Can also type APN into the search bar when you click on Settings)
01-20-2024 08:09 PM
