I can not find the APN setting in my iphone 14, please help!
anqizha_2491732
I was told that I should change my APN setting or I can not use smarty service outside UK by smarty.co.uk when I login my account. However, I can not find the APN setting in my iphone 14. I ask Apple service. It said I sould ask service provider if i can not find APN setting in iPhone.
And I do not know smarty service number.
Please help? Thanks a lot
@anqizha_2491732  Try Settings > Mobile Service >  (Three) Mobile Data Network > (MMS) APN
(Can also type APN into the search bar when you click on Settings)
