11-03-2023 02:13 PM
I'm going to India on holiday, will I be able.to use my phone
11-04-2023 02:58 PM
@LindaYou_917207 Assuming that you are somewhere with mobile signal, then the answer is yes.....but it won't be cheap!
Take a look at the Price Guide - Roaming rates p19 &p20.https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*16p78da*_ga*MTI0NTQ0NTM2MC4xNjk4Njg5Nzky....
Where possible, it may prove best to use something like WhatsApp via any free wifi you can find (always assuming the person you are calling has that App!).
