27-08-2023 18:58 PM
Do I have to activate an add on.
I bought a 1gb add on this morning
It shows on my account. but I am not able to use it.
do I need to activate it somehow?
30-08-2023 08:31 AM
Thanks yes I do have an active account, the add on took 24 hours to activate for some reason however. It’s working now.
27-08-2023 20:10 PM - edited 27-08-2023 20:11 PM
No, no need to activate it.
Do you still have some data left in your normal plan, which would be used before the data in an add on ?
Do you have coverage / signal where you are ?
Are you at home or abroad ? If abroad, the APN in your phone will need to be set to ‘mob.asm.net’
Instructions on how to the APN for both iOS and Android are pinned at the top of the Chats and Hacks” section of this forum
30-08-2023 08:38 AM
Thanks, add on took 24 hours to activate for some reason, haven’t changed anything but it’s working now.
28-08-2023 09:21 AM
@SharonD_1309696 Are you roaming or in the UK? If you are EU roaming, and have used more than 12Gb of data, you would also need an EU Roaming Data Pass for one or three days. Please take a look at the Price guide: https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf
30-08-2023 08:36 AM
In the UK. Add on took 24 hours to activate for some reason but it’s working now thanks.
29-08-2023 11:36 AM
Hey @SharonD_1309696
Some great answers from @MSF & @JJP2!
It is also worth mentioning that you need to have an active account to use the add-on! If you have purchased an add-on and not renewed your plan, the add-on will not work. Please ensure your monthly package is renewed before using any purchased add-ons!
I hope this helps 😊
30-08-2023 08:31 AM
30-08-2023 08:58 AM
@SharonD_1309696 Just wondering if it's possible that your bank took a while to clear the funds for some reason?
06-03-2024 20:59 PM
This is absolutely ridiculous; Surely the whole purpose of buying add-on data is because of the very fact that you have run out of it. Why bother if your monthly contract as already since been renewed
I have had exactly the same problem. Having fun out of data and having since had to purchase an add-on, but can I hell as like get it to work?
Anybody else had the same problem? Any ideas?
Regards, Anne.
06-03-2024 23:49 PM
My old post above from back in August 2023, some of which, regarding travel abroad, may not be relevant in your case.
Instructions on how to the APN for both iOS and Android are pinned at the top of the Chats and Hacks” section of this forum ”
At least the add on doesn’t expire.
08-01-2025 01:15 AM
I put add on and after 24 hours it's still not working
08-01-2025 07:47 AM
@DarrenT_3120084 Check in the Price Guide that you purchased the correct add on
12-05-2024 19:57 PM
I have bought 2 lots of addons, both no obvious place to click activate. 1 has apparently expired, one shows 20 Gb left and no way to activate. Data plan does not restart for 10 days.
This is ridiculous - Smarty taking money but not providing data - most normal providers would have ability to start next plan early, or at least have an activate button or something.
Help is simply auto responders asking "how did we do" - they have given no help whatsoever.
12-05-2024 20:29 PM - edited 12-05-2024 20:32 PM
Smarty Add On’s Never expire.
They also kick in automatically.
See here :
https://help.smarty.co.uk/en/articles/982374-our-add-ons
Also, read this thread.
11-10-2024 21:45 PM
Anyone have any luck with this?
Just purchased 3 day unlimited data add on as have run out and I can’t get it to work. The countdown has started on my dashboard but not actually been able to use it for the 40 mins since I have paid for it.
Extremely frustrating as just moved house and need it until my broadband band is connected.
13-10-2024 09:37 AM
@Samholli Reply on other post.
29-11-2024 18:58 PM
Hi. I have the same issue. Bought a 2gb data add on. It says it’s active but no internet.
30-11-2024 10:11 AM
@JohnC_34049 You need to web chat with Smarty Support Team as only they can access your account to check.
18-02-2025 09:50 AM
Turning my phone off and on again fixed it for me
