Can i use my smarty in spain and Portugal and will i still get my unlimited data?
JayneWo_1632196
JJP2RidesAgain
You need to change the APN in your phone to “mob.asm.net” - see the help videos in this forum if you don’t know how to do this.
No, you will not get unlimited data - It’s a maximum of 12 GB, depending on your plan. If you need more than 12 GB, you will need to purchase a data add on
@JayneWo_1632196 I advise that you check out the Price Guide nd also the Smarty page on Roaming: https://smarty.co.uk/roaming
Andrew_239836
You can unlock your Unlimited data with the £3 per day £7 per 3 days add on should you exceed the fair use 12GB
