29-09-2023
11:57 AM
- last edited on
29-09-2023
16:40 PM
by
Hi,
Do you get free smarty to smarty calls? So for example, if my daughter couldn’t afford her payment one month and had no allowances, could she still call me?
thanks
29-09-2023 12:14 PM
Afraid not, all calls come out of your plan allowances as normal and require an active (paid) plan to use .. if the plan is not active then the service will cease to work.
Same goes for if you don't have any allowances left e.g. no data, you'd need to wait until your allowances refresh or purchase an add-on temporarily. Although calls are unlimited anyways.
29-09-2023 22:20 PM
Ok thank you!
29-09-2023 12:14 PM
29-09-2023 22:20 PM
Ok thank you!
