JohnSimp_579675
24-02-2024SMARTY Pioneer
Which plan for a mobile wifi unit
I have a wifi unit in my motorhome, use it for basic internet browsing etc via ipad, do I just need a data sim in this case? Thanks
24-02-2024SMARTY Guru
JohnSimp_579675 As Linsey says, but also be aware that you will effectively be inside a metal box and this can act as a Faraday Cage, shielding you from electromagnetic waves. Some people have reported difficulties using mobile inside motorhomes/caravans.
