Using my phone in Canada
GordonM_1872598
I go to Canada on Monday 20th March.
Can I use my phone there or do I need to do Anything.
I have already got a ยฃ15 Add On
Can I use WhatsApp in Canada.
Also, data will be charged at 25p PER Mb and calls at ยฃ1.00 per minute, so ยฃ15 may not last long. Canada is in band 2 in Price Guide: https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf P18 & p19
As @Chalkychap says but you will need a fairly good connection in order to use WhatsApp on wifi. Some places deliberately limit wifi as they don't want a few people hogging the whole bandwidth.
You should be able to use your out-of-plan add-on in Canada @GordonM_1872598, although ยฃ15 might not go far if you're using your phone a lot while roaming in Canada.
To use mobile data in Canada you'll to setup the APN as detailed in the online help article:
https://help.smarty.co.uk/en/articles/2045756-setting-up-your-phone-to-work-abroad
To use WhatsApp in Canada you'll need to have a Wi-Fi connection, or mobile internet connection.
